![]() | Home > Puma (Tdci) > 2012 Puma wiper motor and park sensor |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 73 ![]() ![]() ![]() |
Might be worth checking you haven’t overtightened any of the fixings for the spindles or drove cable. Something may be causing the cable to jam, stopping the motor and then blowing the fuse.
NThompson1 Member Since: 25 Mar 2023 Location: West Sussex Posts: 2 ![]() ![]() ![]() |
Thank you for reply, you’re right by re checking, went back over, cleaned up grease that I had put on the electrical connections from re greasing the cable by accident and all worked.
Thanks again Nathan |
