![]() | Home > Technical > A favour from someone with 110 4/5door please.. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
Morning, just going a dry run install of my rebuilt rear tub and sills/b-pillars onto my new chassis. As i have ended up changing so many parts, i have now lost my reference points unfortunately. I want to try and make sure everything fits before it gets painted though so i can avoid having to modify too much at that point.
What i am struggling with is the interface between the C-pillar and the rear tub sides. Would someone be able to take a few photos of the interface between the C-pillar, tub and rear capping just inside the rear door please? It would be mega helpful if someone could confirm a few dimensions for me too please: 1. Depth of the return which the second row door seal fits onto at the C-Pillar (below the level of the capping). 2. Second row LH Door Aperture size (B-pillar to C-pillar) 3. Second row RH Door Aperture size (B-pillar to C-pillar) Would be very grateful if someone would be willing to help out please? Thanks, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 400 ![]() ![]() ![]() |
A few more pics
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
That is absolutely brilliant thankyou
![]() Yours looks to be original too which is even better. Would you just be able to confirm for me that, in your penultimate picture, the front edge of the C-pillar vertical box section is roughly aligned with the edge of the capping? Many Thanks, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Well...I've just been outside in my bath robe with a torch and the phone. Two things happened - I found out how rusty my tub is getting and I very probably flashed a neighbour (she nearly had a stroke, but I was too quick for her, lol!)
However, I have got a photo which I think shows the detail you want. ![]() Click image to enlarge |
Ideal thankyou!
