Home > Technical > A favour from someone with 110 4/5door please..
rallysteve
Morning, just going a dry run install of my rebuilt rear tub and sills/b-pillars onto my new chassis. As i have ended up changing so many parts, i have now lost my reference points unfortunately. I want to try and make sure everything fits before it gets painted though so i can avoid having to modify too much at that point.
What i am struggling with is the interface between the C-pillar and the rear tub sides. Would someone be able to take a few photos of the interface between the C-pillar, tub and rear capping just inside the rear door please? It would be mega helpful if someone could confirm a few dimensions for me too please:
1. Depth of the return which the second row door seal fits onto at the C-Pillar (below the level of the capping).
2. Second row LH Door Aperture size (B-pillar to C-pillar)
3. Second row RH Door Aperture size (B-pillar to C-pillar)
Would be very grateful if someone would be willing to help out please?
Thanks,
Post #982420 14th Feb 2023 12:30pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi Steve, hope this helps, from my 2002 Td5 CSW. Excuse the tape measure, best I could find. For clarity the door seal measures lip measures 21mm square. I think that's what you were looking for. Left hand side is the same plus/minus 3mm on the door opening.
Martin
Post #982439 14th Feb 2023 3:14pm
Penfold_6290
A few more pics
Post #982440 14th Feb 2023 3:24pm
rallysteve
That is absolutely brilliant thankyou Thumbs Up
Yours looks to be original too which is even better. Would you just be able to confirm for me that, in your penultimate picture, the front edge of the C-pillar vertical box section is roughly aligned with the edge of the capping?
Many Thanks,
Post #982447 14th Feb 2023 5:08pm
Penfold_6290
Well...I've just been outside in my bath robe with a torch and the phone. Two things happened - I found out how rusty my tub is getting and I very probably flashed a neighbour (she nearly had a stroke, but I was too quick for her, lol!)
However, I have got a photo which I think shows the detail you want.
Post #982479 14th Feb 2023 9:32pm
rallysteve
Ideal thankyou!
Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #982570 15th Feb 2023 8:15pm
