![]() | Home > Maintenance & Modifications > best replacement fuel pump TD5 |
Siemens VDO only 02' 110 TD5 Double Cab Rebuild Thread
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5294 ![]() ![]() |
https://www.lrparts.net/lrc2382-defender-9...-ring.html
this do ? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6669 ![]() ![]() ![]() |
Looks to be a great price for a VDO, especially with all the fitting parts included.
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 ![]() ![]() |
Hello,
Sorry for joining the thread and maybe hijacking the thread This afternoon I replaced a whining VDO fuel pump (been there 7+ years) with a Hitachi unit labelled HUCO Made in Germany. It was a cheap unit. Has anyone every rebuilt a fuel pump (replacing the motor?) there are some on ebay "continental VDO" priced at around £162 https://www.ebay.co.uk/itm/394027335776?ep...R-j2q-7MYg does it make sense? I am stripping the pump and the high pressure line (green one is difficult to come off the motor. does it make any sense? pump body is still ok no cracks or snapped parts so far. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Don’t waste your time with the cheap ones, VDO only. I’d rather fit a second hand VDO than a new aftermarket.
i found the thread about rebuilding the pump.
fingers crossed about the Hitachi one. It was meant to be a temporary fix while i see if rebuilding the old VDO would work. when it starts whining i will try replace its motor with a VDO one if the housing is similar. i will be rebuilding the old whining VDO once the motor arrives. Hopefully I snap nothing along the way. |
