Home > Maintenance & Modifications > Front shock turret ring replacement |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4350 |
You do not need to, no.
On the ground
Wheel off. Shock and turret out. Undo the bottom spring mount bolts. Jack up to get chassis high-ish on axle stands. Lower jack. Catch front spring as it falls out. The most I have ever had to do is push down on the hub to be able to ease the spring and seat into place. Then refit. |
18th Jan 2023 3:37pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
You could also go in from the top like this: https://www.defender2.net/forum/topic16066.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
18th Jan 2023 4:24pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 512 |
Top tip thanks |
18th Jan 2023 4:30pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 1994 |
If you haven’t already purchased a replacement, take a look at the YRM offering. Also worth considering the rubber spring isolators. Click image to enlarge |
18th Jan 2023 6:31pm |
to spring isolators
18th Jan 2023 6:33pm |
Mine is a 110 so front isolators only
18th Jan 2023 7:05pm |
No you can get Old Man Emu isolators for the rear of a 110 or 130...
Here you go: https://www.4x4works.co.uk/product/old-man...im-packer/ |
18th Jan 2023 7:38pm |
andylee Member Since: 29 Jun 2016 Location: South East Posts: 78 |
Can I ask what the isolators are for ??
Im planning a suspension refurb and have new oem springs and old man emu shocks ready waiting to fit as well as yrm turrets and hardware for fixings so should I also be considering these for my 90 CSW ? thanks A |
18th Jan 2023 7:45pm |
So, all they are for is to separate the metal of the spring from that of the chassis. It stops clunks, some say it improves the ride and it does reduce the wear on the chassis mounts.
Most springs come with a thin rubber capping that does a similar thing, but the ones mentioned are thicker and should last longer. That's about the long and short of it. |
18th Jan 2023 7:54pm |
great, thanks for sharing the knowledge, sounds like its worth putting some in then,
A |
18th Jan 2023 8:24pm |
Use Discovery II isolators on the front as they have a built-in turret ring:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
19th Jan 2023 9:13am |
Ditto LRA
19th Jan 2023 9:20am |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 552 |
I wish I had seen those before I changed my shock turrets.
19th Jan 2023 5:35pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2520 |
You’re not really missing much to be honest.
19th Jan 2023 10:11pm |
