![]() | Home > Maintenance & Modifications > Front shock turret ring replacement |
You do not need to, no.
On the ground
Wheel off. Shock and turret out. Undo the bottom spring mount bolts. Jack up to get chassis high-ish on axle stands. Lower jack. Catch front spring as it falls out. The most I have ever had to do is push down on the hub to be able to ease the spring and seat into place. Then refit. ![]() |
You could also go in from the top like this: https://www.defender2.net/forum/topic16066.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 610 ![]() ![]() ![]() |
Top tip thanks ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
If you haven’t already purchased a replacement, take a look at the YRM offering. Also worth considering the rubber spring isolators. ![]() Click image to enlarge |
Mine is a 110 so front isolators only
No you can get Old Man Emu isolators for the rear of a 110 or 130...
Here you go: https://www.4x4works.co.uk/product/old-man...im-packer/ |
andylee Member Since: 29 Jun 2016 Location: South East Posts: 99 ![]() ![]() |
Can I ask what the isolators are for ??
Im planning a suspension refurb and have new oem springs and old man emu shocks ready waiting to fit as well as yrm turrets and hardware for fixings so should I also be considering these for my 90 CSW ? thanks A |
So, all they are for is to separate the metal of the spring from that of the chassis. It stops clunks, some say it improves the ride and it does reduce the wear on the chassis mounts.
Most springs come with a thin rubber capping that does a similar thing, but the ones mentioned are thicker and should last longer. That's about the long and short of it. |
great, thanks for sharing the knowledge, sounds like its worth putting some in then,
A |
Use Discovery II isolators on the front as they have a built-in turret ring:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Ditto LRA
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
I wish I had seen those before I changed my shock turrets.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2748 ![]() ![]() |
You’re not really missing much to be honest.
