Home > Puma (Tdci) > Diff lock cannot be selected |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4401 |
Ahhhhh Use it or lose it my friend...
It is likely that the C-clip that connects to the diff lock actuator has corroded in place. It is a common thing on Land Rovers that do not get used often. Circled in red. Click image to enlarge Whatever you do... Do NOT force it... |
16th Jan 2023 8:34pm |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 |
Thanks your right use it or lose it.
I will have a look to see what is involved not been into this part of my Landy so far. Much appreciated thanks. |
16th Jan 2023 8:41pm |
The first step is going to be removing the matting and transmission tunnel then you can look down on to the linkage. You might be able to work it loose with some penetrating oil and a little heat. If it is stuck solid then it looks like you cannot buy the bits of the linkage separately for the Puma. So fingers crossed you can work it loose
16th Jan 2023 8:54pm |
That sounds a good plan.
I was looking at the Haynes manual and it tells me nothing. I will do a bit of exploring tomorrow in day light You have been a great help thanks. |
16th Jan 2023 9:01pm |
You are welcome. any problems just shout out, there are loads on here who can help.
16th Jan 2023 9:17pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2591 |
7 years without using the CDL???? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
16th Jan 2023 10:18pm |
Happens more often than you would think...
16th Jan 2023 10:20pm |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 992 |
My old neighbour always said to stick it in reverse and try lock the diff at super slow speed backwards, never had the bottle to try it myself, could never fathom that reasoning Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
16th Jan 2023 11:03pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1760 |
You can get at it from under the vehicle , with a good torch you can see it and spraying the linkage shown with proper penetrating oil, I.e plus gas, waiting about 10 mins , then doing again, waiting 10 mins then trying to wiggle the lever without too much pressure may get it moving. Once it is moving spray more penetrating oil and see how free it’s moving with someone else moving the lever while you are under the vehicle. That way you can see all the moving parts that need lubricating. When all working use some light spray grease on the linkage to keep it lubricated.
If unsuccessful you will likely need to get at it from above as per geoblokes instructions. |
16th Jan 2023 11:51pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
Why would doing this require "bottle"? I don't understand! |
17th Jan 2023 10:04am |
Bloody good track record of things going bang that ends up costing me more Jumped ship to reliability - Mitsubishi L200
17th Jan 2023 10:55am |
Thanks guys I had hoped to get on it today but will tomorrow.
I appreciate the help. |
17th Jan 2023 6:26pm |
