![]() | Home > Technical > Red Booster - Any negative issues? |
Spurge Member Since: 19 Jun 2015 Location: Lancashire Posts: 9 ![]() ![]() ![]() |
Sounds like it is fitted/ set up wrong. They are a great product, I have fit quite a few to customers cars and had no problems. They must be set up properly though.
Berni99 Member Since: 02 Jan 2022 Location: Bath Posts: 37 ![]() ![]() ![]() |
Hi Spurge. Thanks very much for this feedback. Interesting to know that it must be set up correctly, so it sounds like there is an adjustment to it when fitting? I never got any instructions when it was fitted and the RB website doesn't show much info to help on this.
I will be calling my local LR specialist on Tuesday to discuss what to do next. Regards Berni |
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 520 ![]() ![]() |
I had a RB on my TD5 110. It was installed by the UK supplier himself and features on the website. Was a great bit of kit. However, when I had my clutch changed out to a clutchfix HD I experienced slippage in strong headwinds or ascents after a few days of driving. Was a very simple fix that can be done on your drive with just a spanner or two.
![]() From memory, I undid these nuts to gain access to the boosters master cylinder to make adjustments to the 2 locked nuts on the end of the threaded rod. I made minor adjustments, remounted, and tested it each time until the bite was exactly how I liked it - slippage removed of course. It's not at all a challenging job, just time-consuming - worth saving yourself a bunch of labor costs and giving it a go. ![]() (random master cylinder image) Stuart ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 ![]() ![]() ![]() |
good product but a real PIA to set up
Hi Smyles
Great info and thanks for the pictures which really help. I had wondered if there's an adjustment. The AA is due shortly at my house and this is just in time for us to look at! I will report back later in the week. Regards Berni |
Hi KISSMYAURA
again my thanks for this feedback. It just seems too tricky to live with. I will see how the AA get on today and if needed ship it to my local LR specialist. Fingers crossed the friction plate is not destroyed like the first time! ![]() All best Berni |
Thanks All, for your helpful guidance. Witth the AA's support, I drove from home to the specialists - and got less than 3 miles before losing all traction! No smell of any clutch burning so sounds like the Booster is not releasing enough?
Anyway - I will await the update next week. ![]() |
