Home > Technical > Red Booster - Any negative issues? |
Spurge Member Since: 19 Jun 2015 Location: Lancashire Posts: 5 |
Sounds like it is fitted/ set up wrong. They are a great product, I have fit quite a few to customers cars and had no problems. They must be set up properly though.
31st Dec 2022 6:22pm |
Berni99 Member Since: 02 Jan 2022 Location: Bath Posts: 37 |
Hi Spurge. Thanks very much for this feedback. Interesting to know that it must be set up correctly, so it sounds like there is an adjustment to it when fitting? I never got any instructions when it was fitted and the RB website doesn't show much info to help on this.
I will be calling my local LR specialist on Tuesday to discuss what to do next. Regards Berni |
1st Jan 2023 4:33pm |
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 512 |
I had a RB on my TD5 110. It was installed by the UK supplier himself and features on the website. Was a great bit of kit. However, when I had my clutch changed out to a clutchfix HD I experienced slippage in strong headwinds or ascents after a few days of driving. Was a very simple fix that can be done on your drive with just a spanner or two.
From memory, I undid these nuts to gain access to the boosters master cylinder to make adjustments to the 2 locked nuts on the end of the threaded rod. I made minor adjustments, remounted, and tested it each time until the bite was exactly how I liked it - slippage removed of course. It's not at all a challenging job, just time-consuming - worth saving yourself a bunch of labor costs and giving it a go. (random master cylinder image) Stuart Cummins 130 Build Thread 04 110 Double Cab - Black (gone) 58 130 Double Cab HCPU - Cairns Blue |
2nd Jan 2023 7:56pm |
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 |
good product but a real PIA to set up
2nd Jan 2023 9:37pm |
Hi Smyles
Great info and thanks for the pictures which really help. I had wondered if there's an adjustment. The AA is due shortly at my house and this is just in time for us to look at! I will report back later in the week. Regards Berni |
3rd Jan 2023 1:42pm |
Hi KISSMYAURA
again my thanks for this feedback. It just seems too tricky to live with. I will see how the AA get on today and if needed ship it to my local LR specialist. Fingers crossed the friction plate is not destroyed like the first time! All best Berni |
3rd Jan 2023 1:45pm |
Thanks All, for your helpful guidance. Witth the AA's support, I drove from home to the specialists - and got less than 3 miles before losing all traction! No smell of any clutch burning so sounds like the Booster is not releasing enough?
Anyway - I will await the update next week. |
5th Jan 2023 5:30pm |
