![]() | Home > Technical > 130 gvw change |
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 694 ![]() ![]() ![]() |
https://www.defender2.net/forum/post910826.html#910826
The above discussion covered this topic but with no evidence based resolution. I am convinced it was the introduction of the totally ridiculous Traction Control and ABS to the 130’s ![]() Click image to enlarge 130 Puma HCPU with an Artica 240LR Demountable Camper |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Are you trying to get yours increased or decreased?
I got my unimog downplated to 3500kg from 4400kg without much trouble. ![]() |
MT Member Since: 22 Aug 2014 Location: Scotland Posts: 38 ![]() |
I've done a little digging on this in the past as I was hoping to get my TD5 130 (3500kg currently) plated at 3800kg or more.
I spoke to a few companies and it was relatively simple to get it plated to the combination of the axle weights. To go higher would have been difficult for a TD5. There was discussion of Sailsbury axles being able to take additional weight but I wasn't prepared to swap out axles. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8395 ![]() ![]() ![]() |
Need a 3500 one, trying to find cut off age, so seems 2012 ish. If later will need uplift which 8 have heard is not too tricky. Thank you for replies. Cheers
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2280 ![]() ![]() ![]() |
What's the advantage of up-plating?? Are you planning on building a heavier over land type vehicle??
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
James Speak to SV Tech http://www.svtech.co.uk/vehicles/pickups/ Fairly easy enquiry form on the site They did the Sprinter 319 from 3500 to 4200,, plus train weight California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
cheers Cheers
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
You could try Foleys too - they’ll know and process of applying for higher gvw for their 130 conversions.
http://www.foleysv.com/ |
Organised Chaos Member Since: 20 Dec 2008 Location: Chesterfield Posts: 57 ![]() ![]() ![]() |
Not a 130 but I did have a 110 TD5 pickup, before it got nicked, which I had a tipper back fitted.
I just sent the log book off to the DVLA with an increase in GVW from 3050kg to 3500kg, log book came back a few weeks later with the 3500kg GVW. I then got a blank VIN plate and re-stamped the info on it. I did fit a pair of HD rear springs and a anti roll bar. The MOT class went from class 4 to class 7 and made no difference to the insurance. |
