Home > Technical > 130 gvw change
jst
130 gvw change
I believe there was a gvw change from 3500 to 3380kg at some point for 130s
Does anyone know when this occurred and what age/my vehicle were changed to 3380?
Secondly I was wondering if anyone had experience on getting a vehicles gvw changed. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #976016 29th Dec 2022 10:20pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
https://www.defender2.net/forum/post910826.html#910826
The above discussion covered this topic but with no evidence based resolution. I am convinced it was the introduction of the totally ridiculous Traction Control and ABS to the 130’s
 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #976019 29th Dec 2022 11:02pm
camelman
Are you trying to get yours increased or decreased?
I got my unimog downplated to 3500kg from 4400kg without much trouble.
Post #976028 30th Dec 2022 1:13am
MT
I've done a little digging on this in the past as I was hoping to get my TD5 130 (3500kg currently) plated at 3800kg or more.
I spoke to a few companies and it was relatively simple to get it plated to the combination of the axle weights. To go higher would have been difficult for a TD5. There was discussion of Sailsbury axles being able to take additional weight but I wasn't prepared to swap out axles.
Post #976029 30th Dec 2022 2:03am
jst
Need a 3500 one, trying to find cut off age, so seems 2012 ish. If later will need uplift which 8 have heard is not too tricky. Thank you for replies. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #976135 31st Dec 2022 10:11am
90 Dreamer
What's the advantage of up-plating?? Are you planning on building a heavier over land type vehicle??
Post #976147 31st Dec 2022 11:39am
TJ101
jst wrote:
Need a 3500 one,
James Speak to SV Tech http://www.svtech.co.uk/vehicles/pickups/
Fairly easy enquiry form on the site
They did the Sprinter 319 from 3500 to 4200,, plus train weight California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #976175 31st Dec 2022 4:37pm
jst
cheers Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #976203 31st Dec 2022 7:27pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
You could try Foleys too - they’ll know and process of applying for higher gvw for their 130 conversions.
http://www.foleysv.com/
Post #976204 31st Dec 2022 7:43pm
Organised Chaos
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
Not a 130 but I did have a 110 TD5 pickup, before it got nicked, which I had a tipper back fitted.
I just sent the log book off to the DVLA with an increase in GVW from 3050kg to 3500kg, log book came back a few weeks later with the 3500kg GVW. I then got a blank VIN plate and re-stamped the info on it.
I did fit a pair of HD rear springs and a anti roll bar. The MOT class went from class 4 to class 7 and made no difference to the insurance.
Post #976220 31st Dec 2022 9:52pm
