Home > Puma (Tdci) > PUMA PROBLEM PLEASE HELP
Andrea
Hey guys and girls..
I have a 2009 Puma 90 that has just gone onto 60 000kms. Happilly the car has been an absolute pleasure up to now, i have found myself with a slight niggle. In the morning, i start the car, drive it for about 15rmin then it loses power, goes into a limp mode, NO lights come on at all dash appears 100% normal, if i turn the car off and back on problem gone for the day.... It has also happened whilst climbing a fairly tough hill, but again, switch off, start.. perfect??? Please can some1 assist! Want to get rid of this gremlin so i can enjoy her again.!!
Many thanks Guys.
Post #93790 11th Oct 2011 9:52pm
Eduardo
Strange fault indeed.
Should be still under guarantee so will be good if you can bring it to the dealers.
¿Do you have some access to check the fault codes if something appears?
Cheers Eduardo
Post #93793 11th Oct 2011 10:01pm
K9F
You would undoubtedly benefit from some form of fault code reader! Without a code one could speculate until doomsday what might possibly be wrong!
Dealers I'm afraid or splash out on a reader.....needn't cost much! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #93797 11th Oct 2011 10:29pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Get a scangauge or there are plenty on ebay cheap as 15 GBP.
Post #93806 12th Oct 2011 4:24am
Naks
Andrea, whereabouts are you? Plenty of Landy owners with scangauge/odb2 devices that would not mind loooking at the fault codes for you?
Take it to the stealer asap Thumbs Up --
Post #93810 12th Oct 2011 6:33am
