![]() | Home > Puma (Tdci) > PUMA PROBLEM PLEASE HELP |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Strange fault indeed.
Should be still under guarantee so will be good if you can bring it to the dealers. ¿Do you have some access to check the fault codes if something appears? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
You would undoubtedly benefit from some form of fault code reader! Without a code one could speculate until doomsday what might possibly be wrong!
Dealers I'm afraid or splash out on a reader.....needn't cost much! ![]() Treat every day as if it is your last....one day you will be right!! |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Get a scangauge or there are plenty on ebay cheap as 15 GBP.
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2685 ![]() ![]() ![]() |
Andrea, whereabouts are you? Plenty of Landy owners with scangauge/odb2 devices that would not mind loooking at the fault codes for you?
Take it to the stealer asap ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
