![]() | Home > Td5 > Fuel Pressure Regulator |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
Genuine or branded original equipment (Bosch).
Yes you’ll pay more, but you shouldn’t have to do the job again in a hurry. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
As above.
Make sure you get the right version for your engine, plus gasket. I would also strongly recommend that you buy a small torque wrench to fit the FPR as it is remarkably easy to deform the gasket by over tightening it. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I would also buy the small o-ring 02' 110 TD5 Double Cab Rebuild Thread
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 ![]() ![]() |
I used the X8R repair kit, it came with a genuine regulator and the rest of the gubbins. It took about an hour to fit on the driveway and its been on for about 3k miles and no issues.
You'll need a 3/8th and a load of different sized extensions and a 0-60nm tq wrench and a bucket of brake cleaner. |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1657 ![]() ![]() |
allmakes are ok or bearmach or a branded one will last longer.
the kits dont seem to last well or even work from the start. double check the tiny o'rings are ok and you the correct one for your engine |
Only small problem with that is bearmach don’t exist anymore
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
Use only LR gasket. I had few repairs, when aftermaket gaskets just didnot work. Because the original gasket is cheap, there is no need to use some aftermarket with questinable quality. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 399 ![]() ![]() ![]() |
I can also vouch for the X8R repair kit. I did mine 3 years ago due to a leak (coupled with a leaking rocker cover gasket = messy) and it has been perfectly fine since then.
bearmach maybe gone but their stock is around and many dealers have plenty of stock still to sell.
A.Rubio Member Since: 04 Mar 2017 Location: Rocafort -Valencia Posts: 32 ![]() ![]() |
Regulador de presion Bosch ref.- 0 280 160 575 de 4Bares
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 170 ![]() ![]() ![]() |
+1 from me… |
andyg0141 Member Since: 25 Feb 2022 Location: Glasgow Posts: 28 ![]() ![]() ![]() |
The X8R kits seem to get the best write-up. I purchased one for my TD5 but then found a new genuine FPR for £40 more (eBay bargain find) so ended up replacing the whole thing and thankfully no more leaks!
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 ![]() ![]() |
I can thoroughly endorse the X8R repair kit. It comes with a Bosch FPR included, & good quality O rings & gaskets (covers both early & late FPR units). I have had 10,000Km or so out of this kit, & no problems at all. Cheers, Lionel |
