![]() | Home > Maintenance & Modifications > Brake Pads for 2003 TD5 and 2014 Puma |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
Perhaps can check if you have vented or solid discs on either or both. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 412 ![]() |
They are both solid.
I think this page would answer your question.
https://www.lrdirect.com/sfp000260-brake-p...rge-2-hole 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6207 ![]() ![]() ![]() |
Certainly pre-pume vented and non-vented pads were the same. I can't see puma would be any different. the calipers certainly look the same as td5 and 300Tdi |
You are right DJ. The link to lrdirect also mention it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
