Home > Maintenance & Modifications > Brake Pads for 2003 TD5 and 2014 Puma
roche1800
We have 2 Defenders in the household!
Can you someone tell me that the front brake pads on both these vehicles are the same? That beingBrake Pads for 2003 TD5 and 2014 Puma.
And then do these fit both vehicles Brembo P44015:
width 127 mm
thickness 17mm
height 69mm
no sensors
Bembo website compatible OE part numbers are:
SFP000140
SFP000260
STC1275
Post #971782 20th Nov 2022 12:08pm
Dinnu
Perhaps can check if you have vented or solid discs on either or both. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #971791 20th Nov 2022 1:40pm
roche1800
They are both solid.
Post #971796 20th Nov 2022 2:14pm
Dinnu
I think this page would answer your question.
https://www.lrdirect.com/sfp000260-brake-p...rge-2-hole 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #971868 21st Nov 2022 7:26am
Certainly pre-pume vented and non-vented pads were the same. I can't see puma would be any different. the calipers certainly look the same as td5 and 300Tdi
Post #971869 21st Nov 2022 7:40am
Dinnu
You are right DJ. The link to lrdirect also mention it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #971871 21st Nov 2022 9:37am
