![]() | Home > Technical > Reversing issue??? |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
I have a 2007 TDCi 90 ( ABS & Traction Control) - 18" wheels & lowered 1" ( this is NOT part of the problem IMHO).
Clutch was changed using a Clutchfix HD1 Organic drive plate/cluthfix cover/release bearing , new Control valve & Clutch slave cylinder with adapter. Prior to this and after I am experiencing the following problem. Sometimes not always after a run and I go into reverse the rear of the vehicle makes a horrible clunking sound , the vehicle feels like it is "crabbing" from left to right/right to left as though something is winding up. It doesn't feel like Diff-lock is engaged. The light works ok. I am getting under the vehicle on Monday when I take it to my mate ( who is my MOT tester) - he is very experienced with L-R but I am just trying to pre-empt where or what to look for. Any ideas? Thanks Guy May your life be like toilet paper ; long & useful. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6025 ![]() ![]() |
Are the diffs standard?
Have you had vehicle from new? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Try slackening off the handbrake adjuster a little and see if it helps
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Not had the vehicle from new and l believe diffs are standard.
Interesting thought about hand brake. I assume in reverse l might see or feel the hand brake lever juddering? May your life be like toilet paper ; long & useful. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17990 ![]() ![]() ![]() |
No, all hell can be breaking loose in the drum and you are still unlikely to feel it through the lever
Replacement A frame bush has properly sorted the problem.
Well happy now. May your life be like toilet paper ; long & useful. |
