Home > Technical > Door channel spacers
rallysteve
Afternoon all,
Are the angled corner bits absolute garbage or am i just being thick?
Have got the window channel and spacer kits for the front and rear doors from SP4x4. I know the aftermarket bits are not going to be great quality but there is no way i am paying the stupid prices for the genuine bits.
I have some brand new genuine doors. The long plastic window spacer pieces (which fit under the window channel and space the channel inwards) which fit really well into the door with a nice satisfying snap into position. The window channel fits nice and snugly into the recess. It is the corner pieces I am having trouble with though. I am sure they are meant to fit into the ends of the spacers but it seems they are just too wide and just splay the ends of the spacer profile outwards. They just look a total bodge and dont think will even fit in situe.
You can see in the pictures that the corner profiles just seem too wide to fit inside. Has anyone else come across this?
I am sure i had a similar issue with the ones on my 90 front doors but not to this extent.
Post #970023 5th Nov 2022 1:18pm
rallysteve
As i am happy with the fit of the plastic spacer channels I decided to just 3D print some of the 90 and 118deg corner pieces which are a nice precise fit.
Hopefully these should make building the doors up a bit easier.
Post #970658 10th Nov 2022 6:22pm
Hufflepuff
Interesting Steve. I just bought a set of 5 doors from SP4x4 with their full fitting kits myself, so I might well need to do the same as what you have done with the 3d printed parts. Thanks for the information. 2005 Td5 90 XS
1989 V8 110 CSW
Post #970666 10th Nov 2022 7:00pm
rallysteve
Give me a shout if you need a set or the stl files Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #970677 10th Nov 2022 9:13pm
Dinnu
When my old 90 was falling apart, I had the passenger window channels with their respective plastic trims removed, and the glass was just packed with some closed cell foam and a piece of wood to support the glass Whistle
Years had passed, and when I restored the door I found that the plastic trim (original) had deformed, twisted, warped and what not. Also the corner pieces did not fit. But once everything was placed in the door frame, they looked right again. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #970717 11th Nov 2022 6:28am
