![]() | Home > Puma (Tdci) > TC Boinging when turning right |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Have you got DSC on your truck? If so, have you had your steering wheel off at all, the steering angle sensors need to aligned correctly on refitting. That can cause the issue
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1003 ![]() ![]() |
I don't know if I have DSC. Nor do I know how to check
![]() The steering wheel has definitely been off as it has been replaced by an aftermarket one. |
Won't have DSC on an 07
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
check front sensors and cables to them DEFENDER 90 TDCI XS,
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 615 ![]() ![]() |
Sounds like that when you turn right the cable from the sensor that is clipped to the brake hose is either broken inside the insulation or has touched the wheel and worn through the insulation touching the wheel metal as yo turn. Mine did this on the front right. “Boinged” when turning right.
I replaced the sensor and cable with a blue bag job and it’s all good now. £26 if I recall. |
I'll check the wheel sensors tomorrow. Thanks.
