Home > Puma (Tdci) > TC Boinging when turning right
bodstruck
The traction control on my 07 110 seems to kick in when going slowly, decelerating and turning right. Most of the time the TC light does not come on but it has done occasionally. It sounds like a spring being 'boinged' (technical term, sorry)
Only does it when turning right.
I have unplugged the ABS/TC unit and the noise goes away.
Is there a sensor or something I should be checking or cleaning? Any other pointers? I have read in other posts about it potentially being the difflock lever but it is solidly unlocked and in high.
Thanks
Post #966010 26th Sep 2022 3:43pm
camelman
Have you got DSC on your truck? If so, have you had your steering wheel off at all, the steering angle sensors need to aligned correctly on refitting. That can cause the issue
Post #966011 26th Sep 2022 3:51pm
bodstruck
I don't know if I have DSC. Nor do I know how to check Embarassed It is an 07 XS.
The steering wheel has definitely been off as it has been replaced by an aftermarket one.
Post #966012 26th Sep 2022 4:12pm
camelman
Won't have DSC on an 07
Post #966013 26th Sep 2022 4:15pm
LR90XS2011
check front sensors and cables to them DEFENDER 90 TDCI XS,
Post #966015 26th Sep 2022 4:48pm
Siwynne
Sounds like that when you turn right the cable from the sensor that is clipped to the brake hose is either broken inside the insulation or has touched the wheel and worn through the insulation touching the wheel metal as yo turn. Mine did this on the front right. “Boinged” when turning right.
I replaced the sensor and cable with a blue bag job and it’s all good now. £26 if I recall.
Post #966027 26th Sep 2022 7:50pm
bodstruck
I'll check the wheel sensors tomorrow. Thanks.
Post #966028 26th Sep 2022 7:57pm
