Home > Puma (Tdci) > Clutch Switch
90 Dreamer
Clutch Switch
Looking at swappingout the clutch switch as the truck has always slightly suffered with rev hang n a gear change
Wondered if it requires the clutch bled again afterwards or is it 'dry' ??
Anything else to watch out for?
Post #965168 15th Sep 2022 8:41pm
The clutch switch is dry. There is no connection with the hydraulic system. Darren
Post #965171 15th Sep 2022 8:58pm
90 Dreamer
Perfect, thats what I had presumed but wasn't sure......thanks
Post #965176 15th Sep 2022 9:18pm
90 Dreamer
Just to finalise this......
The clutch switch is WET, it fits into the top of the front Clutch master banjo bolt fitting
Long story but ended up with air on the clutch pedal, removal / refitting of the switch and judicious use of a syringe & brake fluid allowed a solid pedal again........
Happy days as the gear change seems far improved to boot Thumbs Up
Post #965464 19th Sep 2022 8:36pm
Blimey, sorry about that. I must have mixed it up with something else Confused Darren
Post #965472 19th Sep 2022 10:25pm
I replaced the whole thing earlier this year, it is indeed wet and has copper washers each side of the banjo fitting on mine.
I replaced the whole thing.
The Puma and TD5 has a clutch switch but earlier models has the hydraulic pipe Union go straight into the MC obviously without a clutch switch.
Was it the TD5 that introduced a clutch switch or did earlier models have one at all?
I know the TD5 and Puma switches differ in that, on the Puma you cannot just disconnect it - it would need to be a closed circuit.
Right now. Though I went years with a disconnected bypassed clutch switch I now have a new one and it’s active again so as it’s working and brand new I’ll stick to that but never had the slightest issue with it bypassed either. Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~
I got’ love for Britain, I got’ British pride’. 🇬🇧
Post #965536 20th Sep 2022 3:09pm
custom90steve wrote:
... Was it the TD5 that introduced a clutch switch or did earlier models have one at all? ...
The only reason for having a clutch switch is to inform the ECM that the clutch has been thrown out in order to modify the engine's behaviour. Since the TD5 was the first Defender engine to have an ECM, it is also the first to have a clutch switch.
Post #965551 20th Sep 2022 5:33pm
