![]() | Home > Puma (Tdci) > Clutch Switch |
The clutch switch is dry. There is no connection with the hydraulic system. Darren
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2272 ![]() ![]() ![]() |
Perfect, thats what I had presumed but wasn't sure......thanks
Just to finalise this......
The clutch switch is WET, it fits into the top of the front Clutch master banjo bolt fitting Long story but ended up with air on the clutch pedal, removal / refitting of the switch and judicious use of a syringe & brake fluid allowed a solid pedal again........ Happy days as the gear change seems far improved to boot ![]() |
Blimey, sorry about that. I must have mixed it up with something else
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20953 ![]() ![]() |
I replaced the whole thing earlier this year, it is indeed wet and has copper washers each side of the banjo fitting on mine.
I replaced the whole thing. The Puma and TD5 has a clutch switch but earlier models has the hydraulic pipe Union go straight into the MC obviously without a clutch switch. Was it the TD5 that introduced a clutch switch or did earlier models have one at all? I know the TD5 and Puma switches differ in that, on the Puma you cannot just disconnect it - it would need to be a closed circuit. Right now. Though I went years with a disconnected bypassed clutch switch I now have a new one and it’s active again so as it’s working and brand new I’ll stick to that but never had the slightest issue with it bypassed either. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17919 ![]() ![]() ![]() |
The only reason for having a clutch switch is to inform the ECM that the clutch has been thrown out in order to modify the engine's behaviour. Since the TD5 was the first Defender engine to have an ECM, it is also the first to have a clutch switch. |
