Home > Maintenance & Modifications > 300tdi brakes issue
NFIN02
United Kingdom 1989 Defender 90 300 Tdi HT Chawton White
300tdi brakes issue
Hi all, hope you can help. Got a 89 300tdi def 90. Jumped into it last night to take it for a spin cuz it spends of us life parked in garage and noticed my brake pedal was very hard and almost no brakes at all. Any thoughts of what this could be guys? Thanks
Post #962809 25th Aug 2022 5:53am
landy andy
Check your brake servo is working and is being provided with a vacuum.
Before starting engine pump brake pedal, and each pump it should get higher, then whilst holding pedal down, start engine a pedal should fall.
Also once after engine has stopped try pulling the supply pipe out of the servo, and it should hiss, as it should be holding a vacuum.
Post #962810 25th Aug 2022 6:01am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Before starting engine pump brake pedal, and each pump it should get lower, then whilst holding pedal down, start engine a pedal should raise.
A bit back-to-front there @landy andy
Pumping the pedal with the engine off should get the pedal harder/higher. If you then hold the pedal down and start the engine the servo assistance should pull the pedal down a bit.
Post #962822 25th Aug 2022 8:42am
landy andy
Woops. Yep bit too early in the morning Embarassed Embarassed
Will edit it to correct. Thumbs Up Thumbs Up
Post #962827 25th Aug 2022 9:02am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Corrosion round the back of the servo affecting vacuum is quite common on older vehicles
Post #962843 25th Aug 2022 12:09pm
