![]() | Home > Maintenance & Modifications > 300tdi brakes issue |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5926 ![]() ![]() |
Check your brake servo is working and is being provided with a vacuum.
Before starting engine pump brake pedal, and each pump it should get higher, then whilst holding pedal down, start engine a pedal should fall. Also once after engine has stopped try pulling the supply pipe out of the servo, and it should hiss, as it should be holding a vacuum. Last edited by landy andy on 25th Aug 2022 9:02am. Edited 1 time in total |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 846 ![]() ![]() ![]() |
A bit back-to-front there @landy andy Pumping the pedal with the engine off should get the pedal harder/higher. If you then hold the pedal down and start the engine the servo assistance should pull the pedal down a bit. |
Woops. Yep bit too early in the morning
![]() ![]() Will edit it to correct. ![]() ![]() |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 685 ![]() ![]() ![]() |
Corrosion round the back of the servo affecting vacuum is quite common on older vehicles
