Home > Puma (Tdci) > I need one single door hinge...but...
Greyman110
Is there a difference in door hinges?
I need one NSF upper hinge as the door has dropped.
Whats the general concensus on this - Can I just get a hinge from ebay or should I get a specifc LR hinge?
Thanks
Post #960563 4th Aug 2022 6:36pm
rustandoil
The hinge you need is around £11 from Paddocks at the moment, don't forget you'll need to paint it Thumbs Up
Post #960566 4th Aug 2022 6:53pm
Greyman110
Thanks...I'll give them a call as I do need the paint as well!
Post #960568 4th Aug 2022 7:05pm
Greyman110
My door hinge arrived...primed, painted with the colour as defined by the paint code, lacqured....but...
It looks like a different colour!
I guess the original paint is 13 years old but faded that much or is my colour off?
Post #961424 12th Aug 2022 2:21pm
Your new paint looks closer to the body than the old hinge Confused Darren
Post #961426 12th Aug 2022 2:39pm
Stacey007
As above I think the new hinge looks more like the car...
13 years of road grim and washes makes the other one look dull.
As aside couple of question as I think I need 1 on the passenger side top?
Are they easy to swap.
How did you paint? rattle can?
Thanks
Post #961429 12th Aug 2022 3:48pm
stacey007 wrote:
...Are they easy to swap? ...
Yes, disturbingly so, unless you have taken measures to deter thieves from stealing your doors, in which case it can take several days to get the old hinge bolts out!
Post #961436 12th Aug 2022 4:33pm
Co1
Just slather the new one in grease and dirt and it will blend right in with the old one!!
Post #961444 12th Aug 2022 5:06pm
Greyman110
I haven't put it on yet as I want to do the lower door seal at the same time so will take the door card off and do everything then. Just need to find the time.
Spraying was easy and it was the first time i've ever sprayed anything!
The paint can came with a fan nozzel so you get a nice even coat. I gave it two coats of everything just to be sure Laughing
I'll take a picture once its fitted as maybe it will look better lol.
Like Co1 said...I'll give it a good blast of lithium spray so it will blend in Rolling with laughter
Post #961448 12th Aug 2022 5:33pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I do think the metallic particles come out more dense from a rattle can than a proper sprayer making it look slightly different. Mine is Orkney grey and my rattle canned hinges look slightly darker.
Post #961460 12th Aug 2022 6:39pm
