![]() | Home > Puma (Tdci) > I need one single door hinge...but... |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 858 ![]() ![]() ![]() |
The hinge you need is around £11 from Paddocks at the moment, don't forget you'll need to paint it
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 ![]() ![]() |
Thanks...I'll give them a call as I do need the paint as well!
My door hinge arrived...primed, painted with the colour as defined by the paint code, lacqured....but...
![]() Click image to enlarge It looks like a different colour! I guess the original paint is 13 years old but faded that much or is my colour off? |
Your new paint looks closer to the body than the old hinge
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3851 ![]() ![]() |
As above I think the new hinge looks more like the car...
13 years of road grim and washes makes the other one look dull. As aside couple of question as I think I need 1 on the passenger side top? Are they easy to swap. How did you paint? rattle can? Thanks |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17873 ![]() ![]() ![]() |
Yes, disturbingly so, unless you have taken measures to deter thieves from stealing your doors, in which case it can take several days to get the old hinge bolts out! |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3726 ![]() ![]() ![]() |
Just slather the new one in grease and dirt and it will blend right in with the old one!!
I haven't put it on yet as I want to do the lower door seal at the same time so will take the door card off and do everything then. Just need to find the time.
Spraying was easy and it was the first time i've ever sprayed anything! The paint can came with a fan nozzel so you get a nice even coat. I gave it two coats of everything just to be sure ![]() I'll take a picture once its fitted as maybe it will look better lol. Like Co1 said...I'll give it a good blast of lithium spray so it will blend in ![]() |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 688 ![]() ![]() ![]() |
I do think the metallic particles come out more dense from a rattle can than a proper sprayer making it look slightly different. Mine is Orkney grey and my rattle canned hinges look slightly darker.
