Home > Maintenance & Modifications > It’s bleeding……
bear100
It’s bleeding……
Hi chaps
My brakes are still a bit spongey from a recent overhaul with new brake lines, I tried using the Ezbleed kit but it didn’t work at all for me, so bled the entire system using new DOT4, got all the air bubbles out and made sure the liquid was clear.
Can you please let me know the correct method of bleeding them?
I removed the reservoir cap, connected tube from nipple into a small see through pot with brake fluid in, then start engine, open nipple, press down and up on brake until no more air bubbles, press down on brake peddle, tighten nipple, release brake.
Done this on each wheel.
Is that right? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #959474 25th Jul 2022 3:51pm
geobloke
Yup that is right. The only addition is that if you are doing a full bleed then you should start with the NS rear, then OS rear, then NS front and finally OS front wheels.
It is worth checking your brake servo and vacuum pump as well, just to make sure they are working as they should.
Just to give you an indication. I have just replaced all four calipers, pads, servo and master cylinder plus full bleed. The effect is a positive pedal and braking that leaves you hanging in your seat belt. Best braking I have ever had in Miffy and she's never had bad brakes.
Post #959478 25th Jul 2022 4:03pm
Hufflepuff
It is interesting you should ask this question, as I think that there are some slightly differing approaches which people take when manually bleeding with a volunteer pumping the brake pedal.
In your description, you stated:
Press down and up on brake until no more air bubbles, press down on brake peddle, tighten nipple, release brake.
I was under the impression that you were supposed to use the following sequence:
(1) Open the bleed nipple
(2) Press down on the brake pedal, ejecting air and brake fluid through the bleed nipple (DOWN!)
(3) Tighten the bleed nipple
(4) Release the brake pedal (UP!)
(5) Return to (1), until no air is being ejected through the brake bleed nipple.
It would if anyone else could clarify if it is necessary to close the bleed nipple between each pedal stroke please, to avoid drawing air back into the system? 2005 Td5 90 XS
1989 V8 110 CSW
Post #959513 25th Jul 2022 9:13pm
donmacn
Hufflepuff, that's my understanding.
I thought I'd just comment on the Eezibleed thing. I have one, and I know I'd been happy with it in the past, but the last time I was doing anything on the Defender I just wasn't getting anywhere.
I opted (more £) for a pressurised bleeding kit, with a bigger reservoir and a hand pump - sealey I think. Not unlike the sort of thing you might use for gardening.
I think it paid for itself first time out. It means you can just set up, with fluid and pressure in the big bottle, and just work your way round. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #959514 25th Jul 2022 9:19pm
bear100
It’s my understanding that using a pot with fluid in and the end of the tube submerged in fluid negates the option of closing the nipple, if there were no fluid in the pot and the foot brake came up there is a high chance air would be sucked back in if the nipple remained open.
That’s how I look at it?
The Ezbleed kit kind of worked but very very slowly I don’t think it had enough pressure to push through ? 2023 Defender L663 V8
Post #959519 25th Jul 2022 10:02pm
Hufflepuff
I have the Sealey pressurised system myself Donmacn, but I've not used it yet, so was pleased to read your positive statement on it.
https://www.sealey.co.uk/product/563720632...ing-system
I used to use a Vacuum system, similar to:
https://www.frost.co.uk/eastwood-brake-bleeder/
but the one time I used it to bleed the clutch, I found it pretty hopeless - it just kept pulling air through continuously. I think the fitting onto the bleed nipple actually allowed air into the system, I couldn't see where else it was coming from! 2005 Td5 90 XS
1989 V8 110 CSW
Post #959520 25th Jul 2022 10:54pm
landy andy
The OP mentioned doing with engine running, which I don’t do. Engine is off when I do it. But when I change fluid on the Defender, I start by sucking out the old from the reservoir with a syringe, then fill with fresh fluid and then start opening each bleed point. And if just a fluid change I just allow gravity to take effect and the new fluid appears. Then to finish off a couple of pumps, then a five or six pumps with bleed shut, hold down, release bleed. I think that emptying res, then gravity save loads of pumps on the pedal which is hard/pointless work for the master cylinder.
Most garages use a vacuum bleed, rather than pressurising system. The basic models of these can be bought cheaply.
Post #959547 26th Jul 2022 10:19am
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
When bleeding normally doesn’t get a good firm pedal try this.
At each corner after bleeding using the process that others have mentioned above, close the nipple and then pump the break pedal five or six times until firm, maintain firm pressure on the pedal. Then quickly crack the nipple open and the pedal will obviously drop to the floor then close nipple quickly. 2011 130 Utility Body
2005 110 Van
Post #959638 26th Jul 2022 10:05pm
MalteseRover
Malta
i am currently trying to bleed my 2003 110 all discs and no ABS system.
I tried alone, master cylinder gravity bled with all unions loose. and the rest of the system with manual bleeding by pumping the pedal and holding it down with a block of wood while I open and close the bleed valve. I have also tried gravity bleed on all four corners.
I would try clamping all the flexi hoses to check pedal but have no decent clamps.
Pedal travels about 1 and a half inch but always stays at the same place.
This is the first time for me on bleeding this systems. I am used to bleeding the series 3 which involved adjustments here and there at wheels and pedal but I do not think this system has got any adjustments involved.
thanks.
joseph
Post #1044783 4th Sep 2024 3:25pm
landy andy
If you are not getting air, and the pedal is firm, but you feel that the pedal is too low, adjust the servo to master cylinder pushrod, rather than keep bleeding system.
Post #1044815 4th Sep 2024 8:21pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
All I do is half fill a beer bottle with fluid, connect a rubber pipe, open the bleed screw, pump out about half of the reservoir then tighten the bleed screw. Go round until all corners are done. If it’s really dirty go round again until the fluid comes out clear. A see through pipe and bottle helps as does an assistant, then you can watch for bubbles in the pipe. I’ve also done the other methods, but it doesn’t seem to make any difference, so long as you get rid of the air and old fluid. As said adjusting the push rod to servo rod makes a lot of difference to the feel, but not too much or the brakes will drag, get hot, expand and stick on.
Post #1044836 4th Sep 2024 10:39pm
MalteseRover
Malta
The system was completely rebuilt (new s.steel pistons and seals and new MC and Servo and half of the solid pipes replaced as well as flexis.
I am starting to wonder if some of the old pistons were seized in the calipers, would it help create a firmer pedal with little travel? I guess i am over thinking.
i gravity bled them all day today and the reservoir was topped up more than 15 times from minimum level so I guess there should not be any air in it. I noticed few particles passing but no major air bubbles. just one instance
I was thinking about adjusting the rod on the servo but i will try bed in the pads and new discs before I mess with the adjustment.
thanks.
Post #1044956 5th Sep 2024 8:11pm
