![]() | Home > Maintenance & Modifications > D90 Sitting low in front? Wrong or worn out springs |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
Have a look at this thread, especially link to spring heights.
https://www.defender2.net/forum/topic84293.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Soulrider911 Member Since: 04 Jul 2022 Location: California Posts: 119 ![]() ![]() ![]() |
excellent, thank you That PDF is exactly what I needed. I will measure
![]() 2022 Defender 110 SE DIY’er | Always learning |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
It’s quite normal for the rear to sit higher - after all there has to be capacity to carry weight in the rear. Hard tops are even higher at the back.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2380 ![]() ![]() ![]() |
Looks normal to me, soulrider.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2674 ![]() ![]() ![]() |
Cheap options are either 10mm spring spacers at the front or four bags of gravel in the back at £3 a bag at B and Q…..
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1902 ![]() ![]() |
The shipping from B&Q might add considerably to the cost
![]() I also think it looks right ![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
thanks all still learning here, I guess I could permanently affix my smoker to re rear
