hank
Sorry to hear you've got no compression. Explains your crankcase pressure though > 110 XS Double Cab
11th Jul 2022 4:56pm |
Re: Compression Test 0psi | |
Puma22 wrote:I have recently done a compression test, the third cylinder back (I think the order is 1,3,2,4, so cylinder 2?) ...
I think you may be confusing firing order with position. Generally cylinders are numbered 1 to n (where n is the total number) from front to rear, so on a Puma no.2 cylinder is the one between 1 and 3, second from the front. The fact that it is the third cylinder to fire during a full, four stroke cycle, is irrelevant.
11th Jul 2022 6:01pm |
landy andy
Puma22 wrote:I have recently done a compression test, the third cylinder back (I think the order is 1,3,2,4, so cylinder 2?) was reading 0psi.
I will shortly be continuing on with my strip down, however I believe that an inlet valve may be stuck open. There is ‘smoke’ coming from the inlet when cranking for the test. Has anyone come across this before? I can’t find anything online relating to Puma engines and intake valve problems.
The third cylinder back is cylinder three. The 1324 is the firing order not the cylinder order.
12th Jul 2022 9:55am |
