Home > Puma (Tdci) > Better sidelights
Kez
Isle Of Man
Better sidelights
I recently bought a set of 'ultra bright' sidelight bulbs for the front, worked great for all of 2 weeks then one by one the LED's died. Contacted the seller (on fleabay) who immediately sent out a new set FOC. Worked great for all of 2 weeks then one by one the LED's died blah blah blah.
So, does anyone have a recommendation, don't went to just keep repeating the same mistake with different suppliers, is it possible just to get a brighter conventional bulb. Any advice greatly received.....
Post #91399 26th Sep 2011 6:10pm
Just get some proper ones from the mobile centre Thumbs Up
Post #91401 26th Sep 2011 6:28pm
Kez
Isle Of Man
Cant see any bulbs on their site - just horribly expensive units Shocked
Post #91402 26th Sep 2011 6:39pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Have you tried ULTRALEDS?
I've bought stuff from them before, and always had good results.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #91413 26th Sep 2011 7:48pm
As I said get proper ones Thumbs Up Thumbs Up
Post #91415 26th Sep 2011 7:53pm
MartinK
Keen to see how this unravels. I put some LEDs from Autobulbsdirect.co.uk in my xc70's side lights, made a great improvement, and they're now over a year old with no problems (they needed to be cambus corrected).
I was thinking about getting a led bulb upgrade for the Defender, but haven't seen any either (just the full units at +£50 ish like the mobile centre ones).
The "normal" LEDs to replace the bulbs are just 1 watt 207 replicas (or at least the ones I have found)...
I haven't studiued this in detail yet...but...are the front sidelights the same size as the reversing light? Could you use one of these? http://www.brookwell.co.uk/item/8114/led-nas-type-reverse-lamp-
Let us know how you get on please? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #91425 26th Sep 2011 8:32pm
Kez
Isle Of Man
Thanks Shax, think they have just what I was looking for. Re NAS reversing light, much larger than standard side lights, and as mine are recessed in KBX grill would not fit.
Post #91430 26th Sep 2011 8:42pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I put one of these:
http://www.ebay.co.uk/itm/CREE-Q5-POWER-LE...45fa485025
into the stock reversing light on may MY11 90 and it's awesome. It's like a little searchlight.
Regards
Pete
Post #91509 27th Sep 2011 9:18am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
.........no need to drill holes either, can make them just plug straight into you existing Land Rover plug....and if you want to push the boat out, have the DRL kit ones, best of both... Putting Dreams on Drives at JLR Solihull..
Post #91707 27th Sep 2011 11:03pm
Shax
XS Pete wrote:
I put one of these:
Regards
Pete
Just installed one of the above LED lampy gizmos in my reversing light.. Very bright... Well impressed with the amount of light it chucks out.. (thanks to XS Pete for the linky!) ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #92415 3rd Oct 2011 3:58pm
