![]() | Home > Puma (Tdci) > Better sidelights |
| Kez Member Since: 11 Apr 2011 Location: UK Posts: 271
I recently bought a set of 'ultra bright' sidelight bulbs for the front, worked great for all of 2 weeks then one by one the LED's died. Contacted the seller (on fleabay) who immediately sent out a new set FOC. Worked great for all of 2 weeks then one by one the LED's died blah blah blah.
So, does anyone have a recommendation, don't went to just keep repeating the same mistake with different suppliers, is it possible just to get a brighter conventional bulb. Any advice greatly received..... |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Just get some proper ones from the mobile centre
Cant see any bulbs on their site - just horribly expensive units
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391
Have you tried ULTRALEDS?
I've bought stuff from them before, and always had good results.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Keen to see how this unravels. I put some LEDs from Autobulbsdirect.co.uk in my xc70's side lights, made a great improvement, and they're now over a year old with no problems (they needed to be cambus corrected).
I was thinking about getting a led bulb upgrade for the Defender, but haven't seen any either (just the full units at +£50 ish like the mobile centre ones). The "normal" LEDs to replace the bulbs are just 1 watt 207 replicas (or at least the ones I have found)... I haven't studiued this in detail yet...but...are the front sidelights the same size as the reversing light? Could you use one of these? http://www.brookwell.co.uk/item/8114/led-nas-type-reverse-lamp- Let us know how you get on please? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Thanks Shax, think they have just what I was looking for. Re NAS reversing light, much larger than standard side lights, and as mine are recessed in KBX grill would not fit.
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
I put one of these:
http://www.ebay.co.uk/itm/CREE-Q5-POWER-LE...45fa485025 into the stock reversing light on may MY11 90 and it's awesome. It's like a little searchlight. Regards Pete |
| adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389
.........no need to drill holes either, can make them just plug straight into you existing Land Rover plug....and if you want to push the boat out, have the DRL kit ones, best of both... Putting Dreams on Drives at JLR Solihull.. |
Just installed one of the above LED lampy gizmos in my reversing light.. Very bright... Well impressed with the amount of light it chucks out.. (thanks to XS Pete for the linky!) ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
| All times are GMT |
