![]() | Home > Maintenance & Modifications > Td5 front shocks and spring replacement |
Tr90 Member Since: 06 Jan 2020 Location: Essex Posts: 135 ![]() ![]() ![]() |
So. On the back of a successful rear suspension change ( https://www.defender2.net/forum/topic83512.html ) I thought I should give the front a go.
It’s a 22 year old car so I get that things may be a bit tight but……. 5 hours later I got to this stage ![]() Click image to enlarge Couldn’t get the turret through the hole so ended up separating the shock in situ. Parts coming tomorrow to fit so just doing one side today. The drivers side is probably harder. Can’t wait |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 284 ![]() ![]() ![]() |
I used a reciprocating saw with hacksaw blade in , worked a treat.
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
Are those pics 'staged' again for the purposes of taking pics, or are they of the job as you went along??
I only ask because in the last pic there appears to be a pretty big gap between the shock turret and the spring mounting. I'd expect that to be completely closed up? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
As the job went along donmacn.
All tightened now. Drivers side done ![]() Click image to enlarge |
