Home > Maintenance & Modifications > Td5 front shocks and spring replacement
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
So. On the back of a successful rear suspension change ( https://www.defender2.net/forum/topic83512.html ) I thought I should give the front a go.
It’s a 22 year old car so I get that things may be a bit tight but…….
5 hours later I got to this stage
Couldn’t get the turret through the hole so ended up separating the shock in situ.
Parts coming tomorrow to fit so just doing one side today.
The drivers side is probably harder. Can’t wait
Post #953611 25th May 2022 8:11pm
Tr90
Continued……
Ok. Parts arrived JGS 4x4 super quick delivery. Thank you.
Started at 3pm and finished at 6.
Thought I had some spring compressors but couldn’t find them so went with the jack option.
Which worked
Getting the nut on the bottom of the shock involved two jacks and a bucket load of swearing but got there in the end.
Tomorrow the drivers side.
Post #953704 26th May 2022 5:45pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
I used a reciprocating saw with hacksaw blade in , worked a treat.
Post #953752 26th May 2022 9:41pm
donmacn
Are those pics 'staged' again for the purposes of taking pics, or are they of the job as you went along??
I only ask because in the last pic there appears to be a pretty big gap between the shock turret and the spring mounting. I'd expect that to be completely closed up? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #953809 27th May 2022 11:59am
Tr90
As the job went along donmacn.
All tightened now.
Drivers side done
Post #953817 27th May 2022 1:46pm
