![]() | Home > Maintenance & Modifications > Repair vs Replace Chassis / X-Member |
| DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1502
It sounds like a crossmember replacement is not currently necessary. It hasn't failed an mot and you haven't mentioned any concerns about towing with it.
If that is so, then it would be a waste of time and money replacing it now. If it does need replacing and the rest of the chassis is fine, just do the crossmember. Who knows what will happen tomorrow? It could be stolen, written off in an accident, (unlikely) market values crash or you may even have to sell it for an unforseen reason. In those circumstances the cost of a new chassis and fitting will not be recovered. The whole chassis may eventually deteriorate to a point where it's not worth repairing and replacement is a more sensible option. |
| Benrlelliott Member Since: 29 Dec 2020 Location: London Posts: 25
Thank you for your reply.
Poor girl got an advisory for rust on last MOT. I daily my 90 so a surprise fail is a major headache and one I'm keen to avoid (tend to also use a Kwik Fit for MOT as more convenient, but maybe MOT shopping is something worthwhile to extend life). Towing is currently not a consideration. |
| kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074
Clean it off, and paint it front and back with corroless rust converting primer then chassis in one, then wax it with lanoguard on the back and inside
| Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280
I was in the same predicament about 15 years ago. My crossmember was holed. I decided to replace the X-member as (back then) it was £120 for a X-member vs £1200 for a galv chassis.
The X-member lasted about 10 years or so then rusted through again - although this time the chassis was more hole than metal. Needless to say it sat off the road for almost 3 years and when the 1st lock down came along I took the chance to do the chassis. Another 2 years later and it is 'almost' back on the road. I wish I had just bit the bullet first time round and did the full chassis - however, the X-member did what it needed to do until the chassis was too far gone to save. So it really boils down to £££ and whether or not you are doing the job yourself or paying someone to do it. |
| All times are GMT |
