![]() | Home > Maintenance & Modifications > Big seats (on a budget) discussion |
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233 ![]() ![]() ![]() |
I fitted Mazda RX8 seats in my old 90. They are easy to fit with some box section. There is a choice of leather and cloth, mine were leather with the drivers being electric but worked fine.
I also fitted Vectra GSI recaro seats in to a 110 and Recaro CS seats from a Lotus Elise. ![]() Click image to enlarge 90 300 TDI SW (sold) 130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
I hear you, it would be amazing to have a set of Scheel-man seats, but alas the cost of seats has sky-rocketed and justification is a problem when £1500 gets you just the two seats...
Well, I have never ever been that uncomfortable in Defender seats, but it must be horrid if you are. So, four Defender front seats in a 2x2 format would be a good easy and pretty cheap way of getting comfy seats. If the covers are OK then replacing the foams and refurbing the frames are not difficult at all, plus you can add heaters and lumber support if that is what you want. I have often thought that Evoque seats would probably fit quite nicely in a Defender, but not seen it done yet. But there are a host of non-LR seats that can be made to fit, such as RX* seats or VXR bucket seats. Apart from that any seat can be made to fit but you will have to adapt the Defender runners to fit the base of the seats. Plus using non-defender seats means that you will have to be able to demount the whole seat to get to the battery box. If your seat covers are OK and the frames are salvageable (even if after a good scrub down, re-paint and grease) then the two foams are less than £100 plus paint and adhesive trim spray glue. If you are happy with vinyl then two seat kit from exmoor trim is around £240. Which is very reasonable. Although using Puma seats I am halfway through refurbing Miffy's front seats - https://www.defender2.net/forum/topic53859-390.html |
west4x4 Member Since: 23 Jan 2010 Location: Rutland Posts: 147 ![]() ![]() |
I’d love a set of scheel-mans. I’ve sat in some and they absolutely lovely. I never normally have an issue with defender seats so I presume/hope it’s due to the foams being shot. I’d like what ever I fit to match front and rear even if just with use of after market matching covers so keeping it all Landrover would be best so that could rule out RX8 ones
So as a minimum you need a second pair of Defender front seats, a refurb kit for the original ones and materials to mount the second set in the second row.
Stick a wanted post up on the forum and you never know. |
