![]() | Home > Puma (Tdci) > can you ID these odd parts? |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 874 ![]() ![]() ![]() |
Thaey look a bit like the ball end that a gas strut might attach to
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 532 ![]() ![]() |
Usually fit next to the rear folding seat lower seat belt anchorage on the wheel boxes. Its there to stop the seat belt turning too far and also screws into the seatbelt to chassis bracket under the body.
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1047 ![]() ![]() ![]() |
I’m curious to whether you mean a new galv chassis or had your original chassis galvanised? 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4328 ![]() ![]() ![]() |
I agree, this is what they are. 2007 110 TDCi Station Wagon XS |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 632 ![]() |
Bluest/Linds - thank you very much. Could I be really cheeky and ask if either if you could post a pic so I know where to refit them?
Brickbox - I had mine galvanised. Had it acid dipped by one company, galvanised by a second, resprayed and refitted. |
That’s brilliant to hear that you’ve managed to have the original galvanised - it seems a bit of a touchy area.
Would you mind giving a ball park cost of having your own chassis galvanised, please? Something I’d look into over changing it completely. 2017 L494 Range Rover Sport SVR 2008 2.4 110 Utility Station Wagon XS. |
its not touchy, its pretty straightforward providing the chassis is in good condition. There are plenty of people on forums that say its tricky, but they're usually the people who have never done it themselves and repeat pub-knowledge they've heard about galvanising. I've had quite a lot of galvanising, blasting and dipping done on past restorations and its not that complex. In this case, I didn't have the workshop space available, so I outsourced it.
The reality is that unless your chassis is near-perfect then its probably not worth doing - if you're having to do repairs, then there'll likely be other thin spots and mig-welded repairs do tend to introduce stresses that can cause odd behaviour when dipped. However if its still in good condition then it'll fly through. There's plenty of natural vents in the chassis, so mine didn't need to be drilled or anything either, which is nice. Excluding removal/refitting the costs aren't very high: Acid dipping (Ribble Technologies) - about £350 along with a few other bits Galvanising (Wedge group) - another couple of hundred quid Fettling the zinc/tapping threads - another day or so's work Respray by a bodyshop in 2K black - say another £400 One thing to bear in mind is that if you're paying to have it done, then the labour costs will be substantially higher than a simple chassis swap as its more of a hassle, takes much longer and takes up much more space in the workshop (including tying up a ramp with the body airborne while the chassis is away). Example 1: Galv and paint your own chassis = from above is approx £1250 Example 2: Buy and paint a Galv chassis = £2150 + £400 = £2550. LESS the resale value of a Puma chassis in good nick (approx £1200) = approx £1350 So financially, it doesn't really make much sense unless you desparately want to keep the factory chassis, like I did. For me, I wanted to keep my 90 nice and original and the chassis was spot on so it was worth it. But if I had bought a brand new chassis and sold off the old one (with the ID removed) then it would probably cost the same and would be a lot less hassle. |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 234 ![]() ![]() ![]() |
Hi Gasket
The photo below shows where they go, as Linds Hanson described. ![]() Click image to enlarge Andy |
wonderful, thank you! Just had a look and my 90 has a shiny pair of grade 8.8 hex bolts where the balls should be - guess the garage misplaced them and just used normal bolts instead.
Thank you for the lengthy reply! Much appreciated!
It’s always good to hear opinions from those that have undertaken the task. 2017 L494 Range Rover Sport SVR 2008 2.4 110 Utility Station Wagon XS. |
