Home > Maintenance & Modifications > Paint adhesion best method - chassis and axles
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I am currently doing work on the underneath of the truck. I am having to change an axle case but have outriggers on my list.
I have noted that corrosion mainly occurs in moisture and crud traps. On my chassis I have been brushing it down and applying Lanoguard. I have chosen Lanoguard as I want to be able to monitor the condition of the chassis- it is 30 years old so need to keep my eye on it.
On cleaning things down I have noted the main areas of corrosion are the nooks and cranies that hold mud etc, and also behind loose paint.
I have come to the conclusion that if you paint something you are likely to create corrosion issues, especially over rust . I have tried rust convertors, but so far I am not impressed.
So, if painting a clean surface, what is the best way to make the paint stick like s**t to a blanket?
My next thing to paint is my rear axle case. It's currently in the electrolysis tub, so I am hoping to get most of the rust off before applying paint.
I currently have the following on the shelf;
Phosphoric acid
Bonda Rust Primer
Zinc oxine Primer
Thinners
Brake cleaner
Single pack top coat.
Aquarust rust converter - (not impressed so far)
Lanoguard
Lanoguard grease
The truck has had bulkhead outriggers before and on brushing and poking these ro remove rust you can see how small sheets of paint have been holding moisture in. I think if you can’t get good paint adhesion then it's better being left bare and painted with Lanoguard or another rust prevention soft coating.
Thanks in advance for any help.
Mick
Post #946558 22nd Mar 2022 9:22am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
In my experience there is no substitute for removing all existing coatings / corrosion and applying a high quality paint system to the bare substrate.
The methods I currently use, with good success so far are:
- Blast clean, or if not feasible, clean with a series of abrasives.
- Clean with panel wipe or isopropyl alcohol
- Epoxy prime using 2pack paint system (Jotun Penguard HB)
- Topcoat with 2pack polyurethane topcoat (Jotun Hardtop AX)
In some cases I will use either phosphoric acid (steel) or an aluminium cleaner to remove oxidation. Just ensure you remove all traces before painting.
I use the same process for painting galvanised steel but add the following steps:
- Degrease with screwfix degreaser (5l, great stuff)
- Abrade surface with red scotchbrite
- Degrease 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #946565 22nd Mar 2022 10:09am
X4SKP
Hello Mossberg
You're main observation is correct.
Rust is the reaction of the base element iron (Fe) and oxygen (O) with Water acting as a catalyst.
To prevent (slow this down) all products and all processes employed aim to break (inhibit) the connection between Fe and O with H2O as the 'link'.... That's it.
The Marine world (all Engineering in a Marine environment) probably leads the way. For us land based wanting to do the best, you are right it is possible to actually make things worse by applying (almost anything) poorly and setting up numerous moisture traps, which will accelerate the rust process.
Options...
Move somewhere dry (does not need to be hot, but often is).
Dry out your 'Iron' / Heated / Airconditioned (Moisture out) Environments.
or
Coat your Product well (which is probably where most of us are).
You Question is about Paint Adhesion...
Land Rover (IMO) only just about covered the Chassis and Axles etc... yes there was talk about
'multi step Anti Corrosion Treatments' but the proof is in the Product, almost all Defenders when I look underneath have well established surface Rust, particularly on the Running Gear, with the Chassis, in some areas not far behind.
From my experience I would say that what ever you do, expect to maintain it.
Absolutely the key factors will be Preparation... Products Used and Application
(so the whole Project Shocked )
My experience is limited (four vehicles + 1 Caravan) but the best I think I have achieved is with Dinitrol. I spent around a week in total to do this on a Defender with 6K on the Clock it now has 50K and I'm about to 'Refresh' some areas, but it's lasted really well.
The Process in Outline...
1. Power Washing / Degreasing / Salt removal and Drying of All Areas.
2. Removing all Loose Surface Rust.
3. Keying all surfaces, (Scotch bright or similar) this is tedious but... well Key!
4. Using Fe123 from Rustbuster (rubbish name but good product).
5. Use a quality 2 Pack Epoxy Paint on key areas (those poorly painted... so most of it!).
5. Apply Preparation Dinitrol Products.
6. Apply 3 Coats of Dinitrol Top Coat Product (Mist Coat + 2 Main Coats).
My Approach...
https://www.defender2.net/forum/topic10467...;start=165
I completed this in 2013, and I've been really (really) please how well this Product has lasted.
If I really clean the underside, beyond 'normal' cleaning every few weeks of so, then the original
unbroken finish looks to be there... effectively completely intact. A few Jacking Points on the Axles
are the only (acceptably) casualties over the years...
Big effort, but I've no regrets and would repeat this approach,
or a very similar version of it, if I needed to again.
Good Luck... SKIP
Post #946568 22nd Mar 2022 10:43am
Mossberg
So looking at this, the use of the IPA is to remove all traces of grease etc. I will make sure all grease is removed and then apply phosphoric acid to try and kill off any rest hiding in the pitting, but it dies look like the electrolysis is killing the rust but leaving the black residue. So after using the phosphoric, use the alcohol wipe over thus before painting?
Just a quick question - could I use the thinners or brake cleaner to do the same job as the panel wipe/IPA on the bare steel as I already have that on the shelf - this is ONLY for wiping down the bare steel as I should be able to get some IPA by the time I have the first coat on.
Regarding IPA - where is the best place to get it? If I know where to get it I may be able to pick some up today, otherwise I will have to order online so probably 2-3 days.
Skip, I think your approach would be great if my chassis was not in the state its in. Unfortunately, due to the maturity of mine I am conscious of covering problem patches, though once I am happy with it I may go that route. I have currently covered it with Lanoguard so I can monitor it, as my thoughts are it may be a new chassis in the future so would go galv. I will do the internal chassis rails at some point, but I want to get the rusty bits sorted over the summer before I do that as I don't want to damage the newly applied coating within a month or two!
Thanks for your responses folks, your knowledge will help me but also I am sure others will benefit from reading of your experiences.
Post #946573 22nd Mar 2022 11:27am
When LR spoke of "multi step Anti Corrosion Treatments" what they neglected to mention was that the factory only took the first step, all subsequent steps have to be taken by the vehicle's future owners. Laughing
Post #946575 22nd Mar 2022 11:50am
X4SKP
Hello Mossberg
Break Cleaner
Is a fast-drying solvent cleaner and is good enough to wipe down most surfaces prior to painting*
* accept getting it anywhere near a Powder Coated Part, which softens the coating making repainting
very difficult if not impossible.
Lanogaurd
Is an excellent product i'd be happy to use this, I completed a TVR Chassis with this and it worked really well, Preparation as ever is key, there such a temptation to get to the Top Coat but resist!
Your Defender
It sounds like naturalising your existing (maybe extensive) Rust is the main first step... A good Converter is the best you can do hear, remove loose Rust first, but the hard surface rust that remains is essential for the converter to work (it actually needs this), turning a dark purple/black finish.
Rust Converter
FE123 gives a hard shell like finish when converted, key again this new surface (more gently) than else where and then apply your paint of choice... you could stop here.
Dinitrol
For me going the next step was the main 'safeguard', protecting the paint Preparation below. The Dinitrol Route gives a sort of cushioned but hard enough protective 'Top Coat' there is a sense that the Dinitrol is just compliant enough to deal with vibration, water spray, stone chips etc (they do a wheel arch specific version) and to my eye does not look to have let water through the overall layered approach.
The dangerous / damaging rust on a Defender is mainly from the inside out, so eating through the Chassis until it is structurally compromised. Relatively Thin Chassis add on like Outriggers will be compromised normally at junctions around weld points where the Painted junction breaks down.
A Galvanised Chassis swap would be a game changer and although can be left as-is there is a whole other world of how to paint a Galvanised Coating where White Vinegar wipe down and Acrylic Paints come into their own...
Good luck... SKIP
Post #946581 22nd Mar 2022 12:45pm
X4SKP
What truth you speak oh wise one... Thumbs Up SKIP
Post #946584 22nd Mar 2022 12:48pm
Shroppy
Hi Mossberg,
You may need to scotchbrite the areas you have treated with phosphoric acid / electrolysis and be sure to rinse off all traces of any chemicals as they can react with the paint system. Then yes, IPA / Panel wipe immediately before painting to remove any final traces or fingerprints / chemicals etc.
Brake cleaner would be ok, thinners no. Unless the thinners are the appropriate ones for the paint system you are going to use. Even then, I'd recommend IPA / panel wipe. You can buy both in 5L quantities relatively cheaply online or at your local paint shop. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #946587 22nd Mar 2022 12:57pm
Mossberg
Some photos of the replacement axle casing during various stages of cleaning, ending with some phosphoric acid applied. (Oops - I seem to have them in the wrong order!
Post #946630 22nd Mar 2022 6:04pm
Screbble
You’re doing a grand job Thumbs Up
Looking forward to seeing the pics of you eating your dinner of it Shocked
Keep the pics coming.
Post #946697 23rd Mar 2022 7:53am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
The best way is still sandblasting, followed by good quality zinc primer within max2-4 hours of blasting...bit like welding. All in the preparation.m
Post #946701 23rd Mar 2022 8:09am
Mossberg
I would agree about shotblasting as it will remove all the paint etc, but this is being done to a budget and everything in the main is being done by me. I did see a set of blasted axle cases on ebay but unfortunately after I had purchased this one.
I have tried to remove the paint with the wire brush in the grinder, but it is being stubborn to the extent that I am just going to scotchbrite it before painting. This refurb is for longevity rather than looks so I hope this will suffice.
One thing that has impressed me with electrolysis is its ability to get to those places you just wouldn't reach with other methods whilst not attacking good steel.
I certainly don't think wire brushing is adequate. Where the rust on this was crusty and thick (mainly on the welds), the wire brush removed the surface rust then polished the stuff underneath. A needle gun would probably have worked, but I ain't got one!
Electrolysis is relatively cheap to set up and you can just keep using it over and over. The only consumables are soda crystals and sacrificial anodes. I am using an old style battery charger which is showing about 4 Amos on the 12v setting, but not sure how that equates to electricity use/cost.
You still need to wire brush and scrape/poke after electrolysis but I feel it removes a great deal of rust. The part is often wet when doing this so you get a local mess rather than the airborne dust from wire brushing rust - this makes a big difference to me as even when wearing a dust mask I still end up with it up my nose, which means I am breathing it in.
A pressure washer is very useful for cleaning after electrolysis, but obviously you need somewhere appropriate to use it.
I have gone from a 40 ltr bucket to a 200 ltr barrel. I think this will become a permanent setup as I prefer this method where you have suitably sizes parts.
A shot blaster would be nice though!
Post #946706 23rd Mar 2022 8:55am
X4SKP
Hello Mossberg
Great job, looks really well done so far, with the description you’ve given I wouldn’t worry too much about removing all the paint… there will be areas that ‘put up a fight’ take these as well adhered Exclamation
Good to see the effort at the preparation stage, you’ll get what you’re looking for with this approach.
Continue to Show and Tell… Thumbs Up SKIP
Post #946715 23rd Mar 2022 10:00am
Mossberg
Well, talk about two steps forward and one step back! After applying the phosphoric acid yesterday afternoon, it seemed to be doing a nice job of sorting the remaining residue After the electrolysis and brushing. I ended up going out after I had done it and was back later than expected, so I didn't want to start moving it without washing it down due to the acid, so decided to leave it out overnight as we were due no rain.
Anyhow, got up this morning and had a quick look before nipping out. I looked and it was covered in condensation - never thought of that! Never mind me thinks, I will wash it down when I get back. We'll an hour and a half later I got back and looked at it. What the f*** - the condensation had dried and left a scaly residue on the surface. Unfortunately I tried pressure washing, and whilst it removed some, wire brushing was required to loosen it. Joy!
When wire brushing dust was coming off. A bit of a pressure wash again and as I was getting a milky look to the water as I scrubbed. Anyway I wire brushed and pressure washed and it came up clean. I was going to leave it a couple of days before painting, but flash rusting started to occur.
I decided I would paint it today. I let the axle dry then scotchbright, brake cleaner and wipe. I then applied Bonda Rust Primer. One coat then the next, they both went on thick, with the odd run here and there, but I think I got it covered.
I then let it cure under infrared (it was sunny this afternoon!).
Some photos.
Post #946799 23rd Mar 2022 9:07pm
Screbble
Crumbs - sounds like you’ve had quite a challenge and some really bad luck - but the painted axle looks really good from what I can see.
You’ve probably done a far better job than most Thumbs Up
Just a thought promoted by your pics - I was wondering if you might want to remove the bush cups on the shock absorber rear mounting brackets?
Post #946820 23rd Mar 2022 10:56pm
