Home > General & Technical (L663) > Rear airbag suspension - do they normally lose a little air
abpod
United States
Hi all -
I noticed a year ago when I had my vehicle brand new sitting in my garage that the next morning the rear end of the vehicle looked like it had noticeably sunk. Fast forward to today, I decided to check this again because it looks like it definitely sinks (squats) if the vehicle has sat all day.
So I tested this by going into the rear tailgate and pressing the button in the cargo area to raise/lift the vehicle to its maximum height. I then marked a spot from the passenger rear wheel-well trim to a spot on the passenger rear tire. I let the car sit throughout the day and sure enough the vehicle has already dropped/lowered almost a full inch, meaning it has lost its air hold.
Could someone else please try this out and let your vehicle sit overnight to see if it holds the air exactly where you left it at the fully raised height position or if it too also starts to naturally lose some of the air it was holding?
Many thanks in advance. '21 L663 X-Dyn HSE P400 Carpathian
'13 L319
'03 L322
Post #945905 16th Mar 2022 12:50am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Mine sits for days / weeks at a time with no loss of air.
Post #945917 16th Mar 2022 8:55am
J77
I’m sure my Disco’s rear suspension used to drop slightly if left in normal height. 24MY 90 D250 HSE, Tasman Blue
Post #945939 16th Mar 2022 12:24pm
Vehicles on air suspension shouldn't drop at all overnight, beyond minor variations due to changes in air temperature. Significant change such as the OP describes indicates that there's a leak in the system. Darren
Post #945942 16th Mar 2022 12:35pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Agreed, should keep its height and not sag. Time to splash some soapy water around to find the leak! Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #945947 16th Mar 2022 2:17pm
The_hog
Iceland
Nope!
Post #946001 16th Mar 2022 11:11pm
