![]() | Home > Td5 > Slickshift |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 196 ![]() ![]() ![]() |
Can someone educate me on what different the turret makes over and above the slickshift kit? e.g. this bundle https://www.onlinegearboxparts.com/product...d5-bundle/
over this one: https://defenderupgrades.co.uk/product/lan...t-inc-td5/ |
katana069 Member Since: 28 Mar 2022 Location: Northern Ireland Posts: 44 ![]() ![]() |
I had a Slickshift installed last week and the difference is remarkable. Didn't upgrade the turret as mine was in goog nik with only 120k on the clock
I was going to say might do mine as well as I'm at 125K ... but no idea if mine is worn what are the symptoms?
You could take your original out and have a wee look before you order it only a 45min job.. just a thought..
Joel Member Since: 18 Oct 2020 Location: Rotherham Posts: 76 ![]() ![]() ![]() |
I have just had mine fitted with the new gearbox, and it’s night and day. No more stirring the spanners to change gear.
I would highly recommend. |
Tufty Member Since: 27 Nov 2020 Location: Near Guildford Posts: 19 ![]() ![]() ![]() |
I fitted a slickshift and it made quite a difference to mine at 125k. I should have probably have changed the turret too as mine was borderline, but overall a great improvement - and a heck of a lot easier to fit than the LOF powerspring!
andyg0141 Member Since: 25 Feb 2022 Location: Glasgow Posts: 28 ![]() ![]() ![]() |
I’ve just done the shifter and spring (didn’t do turret as it looked ok even at 140k) and the difference is incredible - well worth it (despite the spring being rather fun to fit!)
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3508 ![]() ![]() |
Well, l've just received the Slick Shift kit for my 140,000 mile TD5 110 so looking forward to seeing what difference it makes.
Did you get a replacement turret as well or retaining the original?
