Home > Puma (Tdci) > Puma overheating
Will
Puma overheating
:x Has anyone experienced serious overheating? I have eliminated viscous coupling, thermostat and waterpump. I have no dealer support and no experience with this engine. Help :blub:
Post #6449 20th Jan 2009 10:55pm
mse
None - have you air con, a bar, winch or spotlights or is the radiator clear? Mike
Post #6452 21st Jan 2009 10:12am
Grockle
Stuck rad'stat ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #6453 21st Jan 2009 10:24am
Grockle
ah'you've checked that, expansion tank cap vent. 2.4 90 XS
Post #6454 21st Jan 2009 10:26am
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
Post #6457 21st Jan 2009 2:57pm
mse
Yes - looks a little like a fire though Laughing Mike
Post #6459 21st Jan 2009 3:13pm
Grockle
No Mike,thats the new charcoal interior Rolling with laughter 2.4 90 XS
Post #6460 21st Jan 2009 3:17pm
The Boy
Thats what mines going to look like if LR don't get their finger out Laughing
Post #6461 21st Jan 2009 3:22pm
Daniel TD5
looks like the sun roof leaks
Post #6462 21st Jan 2009 3:26pm
mse
a way of charging more...i see Mike
Post #6463 21st Jan 2009 3:31pm
islu51
Will,
Can you give us more details on the overheating and we will try to help you. have you checked that the system is still under pressure? Is the expansion tank or cap seal damaged? Is there any circulation or collasped hose? How quickly does it overheat and under what driving conditions?
Post #6464 21st Jan 2009 4:13pm
fekete
Back wheel looks good Laughing NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #6465 21st Jan 2009 5:41pm
AndrewS
Turbo should be OK as it's under the heat shield Razz
Post #6497 22nd Jan 2009 6:43pm
Will
overheating 2.4Tdci
I was hoping someone had come across similar problems. The cap seemed faulty as no pressure, so I sealed it with plastic and it still overheated. I could do with a cooling system diagram as it seems pretty complicated. It is overheating after 15 mins. Ive exhausted my ideas.
Post #6532 23rd Jan 2009 6:06pm
Grockle
Will,you say you think the caps at fault have you tried another one. 2.4 90 XS
Post #6533 23rd Jan 2009 6:25pm
