![]() | Home > Puma (Tdci) > Puma overheating |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
None - have you air con, a bar, winch or spotlights or is the radiator clear? Mike
Stuck rad'stat ? 2.4 90 XS
ah'you've checked that, expansion tank cap vent. 2.4 90 XS
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 ![]() ![]() ![]() |
this one got a tad hot
http://cgi.ebay.co.uk/fire-damaged-land-ro...240%3A1318 dan |
Yes - looks a little like a fire though
No Mike,thats the new charcoal interior
![]() 1968 1/32 scale Britains 109 Pick up. |
Thats what mines going to look like if LR don't get their finger out
looks like the sun roof leaks
a way of charging more...i see Mike |
islu51 Member Since: 08 Mar 2008 Location: Cirencester Posts: 3 ![]() ![]() |
Will,
Can you give us more details on the overheating and we will try to help you. have you checked that the system is still under pressure? Is the expansion tank or cap seal damaged? Is there any circulation or collasped hose? How quickly does it overheat and under what driving conditions? |
Back wheel looks good
Turbo should be OK as it's under the heat shield
Will Member Since: 20 Jan 2009 Location: Tanzania Posts: 3 ![]() |
I was hoping someone had come across similar problems. The cap seemed faulty as no pressure, so I sealed it with plastic and it still overheated. I could do with a cooling system diagram as it seems pretty complicated. It is overheating after 15 mins. Ive exhausted my ideas.
Will,you say you think the caps at fault have you tried another one. 2.4 90 XS
