Home > Puma (Tdci) > Heater advice needed
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
Heater misbehaving blows nice and hot then goes cold for a bit then warm especially bad if fan on max shame as heater is one of the few things that has allways worked on her any advice would be appreciated Endeavour To Persevere
Post #944374 2nd Mar 2022 7:42pm
Check the coolant level. This is a very common symptom of the coolant level having dropped slightly.
Post #944390 2nd Mar 2022 8:58pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Isn’t this relatively normal in winter? I have a radiator grill screen to help stabilise it when the temperature drops to zero ish Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #944395 2nd Mar 2022 9:29pm
Doesn't sound normal at all Confused The efficiency of the heater on the Puma models is one of its best features and provides a steady stream of toasty hot air.. Darren
Post #944407 2nd Mar 2022 10:11pm
Leamreject
It blows out volumes of very warm air until the outside temperature drops to zero and below, then it fluctuates when driving with high interior fan assistance. it’s been the same since I’ve owned it, and to be honest I have always thought it normal. Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #944412 2nd Mar 2022 10:29pm
110 Iain
Checked coolant this morning
Level OK but header tank still presurised
A bit even though cold is this normal
Also dash temp gauge not
Reaching middle after running
At tick over for 15 mins? Endeavour To Persevere
Post #944434 3rd Mar 2022 9:59am
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Not sure about puma but tdi’s and td5 all cool down below normal running temp at tickover especially if heater is blowing as well. Diesels do run more thermally lower than a petrol especially at tickover not uncommon in a lot of modern cars that have dual heater matrices the temp in engine can reduce significantly if both are run at full chat. Hence the need for rad muffs
Post #944437 3rd Mar 2022 10:48am
J1990
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Tamar Blue
My 08 110 does similar with engine temp, doesn't seem to heat up much during tickover but as soon as it's on the road it warms up quickly, if I leave it running once I'm back the engine temp drops off slowly.
Post #944449 3rd Mar 2022 12:50pm
