![]() | Home > Puma (Tdci) > Heater advice needed |
| 110 Iain Member Since: 11 Nov 2019 Location: Scotland Posts: 93
Heater misbehaving blows nice and hot then goes cold for a bit then warm especially bad if fan on max shame as heater is one of the few things that has allways worked on her any advice would be appreciated Endeavour To Persevere
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18044
Check the coolant level. This is a very common symptom of the coolant level having dropped slightly.
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Doesn't sound normal at all
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970
It blows out volumes of very warm air until the outside temperature drops to zero and below, then it fluctuates when driving with high interior fan assistance. it’s been the same since I’ve owned it, and to be honest I have always thought it normal. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Checked coolant this morning
Level OK but header tank still presurised A bit even though cold is this normal Also dash temp gauge not Reaching middle after running At tick over for 15 mins? Endeavour To Persevere |
| Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128
Not sure about puma but tdi’s and td5 all cool down below normal running temp at tickover especially if heater is blowing as well. Diesels do run more thermally lower than a petrol especially at tickover not uncommon in a lot of modern cars that have dual heater matrices the temp in engine can reduce significantly if both are run at full chat. Hence the need for rad muffs
| J1990 Member Since: 24 Aug 2021 Location: South West Posts: 39
My 08 110 does similar with engine temp, doesn't seem to heat up much during tickover but as soon as it's on the road it warms up quickly, if I leave it running once I'm back the engine temp drops off slowly. |
| All times are GMT |
