![]() | Home > Td5 > 1999 TD5 ignition comes on once key removed |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 399 ![]() ![]() ![]() |
I'd be looking very closely at the ignition switch. How do you cancel the fuel pump and the dash lights?
Do you turn it back far enough before pulling the key out?
Mine is a little worn and I can pull my key out with the engine running. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2674 ![]() ![]() ![]() |
‘Their here………….’
![]() Click image to enlarge Well you never know, everything else has happened over the last two years….. ![]() |
andyg0141 Member Since: 25 Feb 2022 Location: Glasgow Posts: 28 ![]() ![]() ![]() |
I think I do....but will pay a bit more attention and check that I actually am! |
It does 1 cycle i.e. fuel pump primes, shuts off and then the ignition lights etc go off |
