Home > Td5 > 1999 TD5 ignition comes on once key removed
andyg0141
United Kingdom 1999 Defender 90 Td5 XS CSW Rimini Red
Trying to iron out some small issued with a new to me TD5. One of them is that when you stop the engine and remove the key, the ignition (fuel pump and dash lights) then fire up again. My first port of call was going to be the ignition switch but before I replace that, are there any other usual culprits?
Thanks, Andy
Post #943993 27th Feb 2022 10:23am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
I'd be looking very closely at the ignition switch. How do you cancel the fuel pump and the dash lights?
Post #944001 27th Feb 2022 1:01pm
roel
Do you turn it back far enough before pulling the key out?
Mine is a little worn and I can pull my key out with the engine running. Whistle Roel
2003 90 Td5 (2009-now)
Post #944028 27th Feb 2022 6:09pm
markb110
‘Their here………….’
Well you never know, everything else has happened over the last two years….. Whistle
Post #944043 27th Feb 2022 8:50pm
andyg0141
I think I do....but will pay a bit more attention and check that I actually am!
Post #944047 27th Feb 2022 9:20pm
andyg0141
It does 1 cycle i.e. fuel pump primes, shuts off and then the ignition lights etc go off
Post #944048 27th Feb 2022 9:20pm
andyg0141
markb110 wrote:
‘Their here………….’
Laughing Hopefully I can get rid of it a bit quicker than the events of the last 2 years!
Post #944050 27th Feb 2022 9:21pm
