Home > Puma (Tdci) > Engine cutting out on motorway
Mollymole13
Hi all,
I am having trouble whilst on the motorway I would drive for 5 to 10 mins fine (sometimes longer) then the engine cuts out and goes into a 'limp mode' where I have no acceleration BUT still driveable at 50
I pull over turn the engine off wait a while and then can go again. But the same thing will happen.
Any advice would be great.
Post #942659 16th Feb 2022 12:12am
Mollymole13
2007 Puma 2.4 for reference
Post #942660 16th Feb 2022 12:12am
Dinnu
Check that it is really not overheating... if that is ok, check the cylinder head temperature sensor.
I would connect to obd and check temperature through that.
The puma will reduce power to protect itself if it reads high cht. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #942664 16th Feb 2022 6:30am
HardCharger
What does your temperature gauge read?
Post #942665 16th Feb 2022 6:33am
MartinK
I had something similar.
Initially cleaned MAF and MAP, but it didn;t completely clear the problem.
Then VCV
Which again changed the issues a bit but not completely.
After a LOT of head scratching I again changed the VCV, when I took the one out it was different!
All here https://www.defender2.net/forum/topic80592.html
I think it was the VCV, but I still have an underlying issue in that it occasionally stalls a few seconds after starting (which I think is a separate issue with the Throttle Position Sensor).
Good luck!!! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #943036 19th Feb 2022 1:27pm
