![]() | Home > Puma (Tdci) > Puma air conditioning switches. |
The lower one turns on the A/C. The upper one has filled what is normally a blank and suggests that the previous owner has re-purposed a switch for something else. Do you have spotlights, by any chance? If so, it could the isolator for them. Darren
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 64 ![]() ![]() |
Hi
Thanks for the reply. Nope no spotlights (yet). I shall have to try and investigate. In the manual was a card with a couple of fuses and a note that said "if no A/C it'll be the fuse!".... Chris |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3765 ![]() ![]() ![]() |
Interesting!! Does it get cold if you turn the one at the top on?!!
Hi,
Haven't gotten around to that yet. Will try tomorrow. Chris |
Hi,
The bottom one kicks in the A/C clutch so that appears correct. The top one appears as yet to do nothing? Except the LED illuminates. Is a Kenlowe style electric fan normal in front of the radiator? It doesn't look like an original part... I am wondering if the previous owner installed this? Chris |
If it looks like this then yes, it's the A/C condenser fan:
![]() Click image to enlarge If the button doesn't do anything obvious then the only solution would be to trace the wiring. The previous owner's fuse warning is a bit suspect though, and suggests an unresolved problem ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Hi,
Yup, that's it. I will have to start unscrewing stuff! It's time anyway..... just to see what I have. Thanks for all the assistance. Chris |
