Home > Puma (Tdci) > Puma air conditioning switches.
Polarismd
Hi New 2008 Puma XS owner here, my 1995 TDI committed suicide in December!
Quick question, this has two air-conditioning switches. One top left of binnacle the other bottom between heated seats switches.
Is this normal? If so what do they do?
Thanks in advance.
Chris
Post #942319 13th Feb 2022 3:38pm
The lower one turns on the A/C. The upper one has filled what is normally a blank and suggests that the previous owner has re-purposed a switch for something else. Do you have spotlights, by any chance? If so, it could the isolator for them. Darren
Post #942331 13th Feb 2022 5:04pm
Polarismd
Hi
Thanks for the reply.
Nope no spotlights (yet).
I shall have to try and investigate.
In the manual was a card with a couple of fuses and a note that said "if no A/C it'll be the fuse!"....
Chris
Post #942333 13th Feb 2022 5:27pm
Co1
Interesting!! Does it get cold if you turn the one at the top on?!!
Post #942344 13th Feb 2022 7:13pm
Polarismd
Hi,
Haven't gotten around to that yet. Will try tomorrow.
Chris
Post #942348 13th Feb 2022 8:14pm
Polarismd
Hi,
The bottom one kicks in the A/C clutch so that appears correct.
The top one appears as yet to do nothing? Except the LED illuminates.
Is a Kenlowe style electric fan normal in front of the radiator? It doesn't look like an original part... I am wondering if the previous owner installed this?
Chris
Post #942412 14th Feb 2022 10:10am
If it looks like this then yes, it's the A/C condenser fan:
If the button doesn't do anything obvious then the only solution would be to trace the wiring. The previous owner's fuse warning is a bit suspect though, and suggests an unresolved problem Confused Darren
Post #942418 14th Feb 2022 10:20am
Polarismd
Hi,
Yup, that's it.
I will have to start unscrewing stuff! It's time anyway..... just to see what I have.
Thanks for all the assistance.
Chris
Post #942427 14th Feb 2022 10:33am
