![]() | Home > Technical > Prop Shaft Lengths changed over years? |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3648
It will be the same length only if it coming off another Puma.
Td5/300 and 200/earlier have different transfer case position relative to chassis, hence different prop lengths. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296
There's some good info about the various lengths on the Gwyn Lewis website 2011 CSW XS 90
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
Salisbury rear diff had a longer nose too, so another combination of lengths. |
| MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 203
Just measured my propshafts the other day on my 110 Puma while greasing them on the bench.
If it can help, front is 675mm closed length, rear is 1070mm closed length. Just be mindful that both front and rear propshafts are phased on a Puma to compromise for vibrations in the driveline. This is needed as the transfer box is mounted with an unusual angle due to the Ford engine and MT82 gearbox assembly. If my notes are correct (I am not under the truck atm), the front propshaft have the two UJ yokes phased 45° with each other, and the rear propshaft have the two UJ yokes phased 67,5°. The later being a magical number from Land Rover engineering excellence, and pretty unique in defender rear propshaft history. So my advice here is also to look at the phasing (which can be reset easily) when re-using Puma propshaft for another project Defender - not only the length. /Mat |
| Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635
MatLandy - that is a golden nugget of info re rear prop phasing.
@Lodelaner Instagram Youtube greenlaning and other LR related content |
