Home > Technical > Prop Shaft Lengths changed over years?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
I pulled the prop shafts in my 2014 puma 110 but now curious if they are the same length as previous defenders? Ie could I use for a NAS or ROW
Project?
Post #941879 10th Feb 2022 3:11am
Dinnu
It will be the same length only if it coming off another Puma.
Td5/300 and 200/earlier have different transfer case position relative to chassis, hence different prop lengths. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #941883 10th Feb 2022 7:46am
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
There's some good info about the various lengths on the Gwyn Lewis website 2011 CSW XS 90
Post #941897 10th Feb 2022 10:00am
miker
Salisbury rear diff had a longer nose too, so another combination of lengths.
Post #941902 10th Feb 2022 10:43am
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Just measured my propshafts the other day on my 110 Puma while greasing them on the bench.
If it can help, front is 675mm closed length, rear is 1070mm closed length.
Just be mindful that both front and rear propshafts are phased on a Puma to compromise for vibrations in the driveline. This is needed as the transfer box is mounted with an unusual angle due to the Ford engine and MT82 gearbox assembly. If my notes are correct (I am not under the truck atm), the front propshaft have the two UJ yokes phased 45° with each other, and the rear propshaft have the two UJ yokes phased 67,5°. The later being a magical number from Land Rover engineering excellence, and pretty unique in defender rear propshaft history.
So my advice here is also to look at the phasing (which can be reset easily) when re-using Puma propshaft for another project Defender - not only the length.
/Mat
Post #942017 10th Feb 2022 11:06pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
MatLandy - that is a golden nugget of info re rear prop phasing. Thumbs Up JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #942056 11th Feb 2022 12:03pm
